H rings
B.W.JOHNSON
08-09-2003 17:05:32
what is the gap between ends of the ring in the cylinder. My standard used ring has .089 between the ends.
Bob
08-09-2003 17:42:42
 Re: H rings in reply to B.W.JOHNSON, 08-09-2003 17:05:32
Rule of thumb is .003" to .004" end gap per each 1" of bore diameter. A used bore is typically tapered from top to bottom, so be sure to check for at least a minimum of ring end gap at the least-worn (lower) area of ring travel. Use a piston with no rings on it to slide the ring down in the bore so it is square before measuring.
