Gasket Sealer for Radiator Tanks
cheg
08-09-2003 06:14:44
Since we are on the topic of gasket sealers, I was wondering which sealer works best for radiator tanks. I replaced the radiator core and used a non-hardening (I think permatex #3) on the gaskets. I still had some weeping. I took the radiator back apart and took the tanks to a machine shop to plane the gasket surfaces. I was wondering what sealer to go back with. I plan to use a thicker gasket since the tanks were machined.
Lee
08-10-2003 00:09:14
 Re: Gasket Sealer for Radiator Tanks in reply to cheg, 08-09-2003 06:14:44
I've been using only clear silicon RTV for this type of application since the early 70's with no real problems. I don't understand the trash talk about going 'only silicone' as it works for me. Carburators not included in 'only silicone' scheme.
Gman
08-09-2003 18:54:31
Cheg-I've used red silicon ,permatex and a very thick gasket,the ones you get from john deere aren't thick enough,I go to machine shop and they got this thick gasket material and I use the John Deere gasket as a pattern.They usually leak when you start them but when you bring the engine up to temperture a few times they usually seal off sometimes you might have to go back over the bolts and snug them up some more. Hope this helps Gman
