Epoxy rear spoked wheel repair ?
Tom
08-09-2003 06:12:02
Has any one tried to repair a broken clamp on the hub of a spoked wheel with epoxy (Like JB Weld)? Welding seems to be a hit or miss thing. Thank you for the help.
Dave K
08-09-2003 13:47:55
 Re: Epoxy rear spoked wheel repair ? in reply to Tom, 08-09-2003 06:12:02
JB Weld is fine where there is no or little stress. Won't work on wheels. Buy a new clamp.
Dave
Bus Driver
08-09-2003 10:00:19
Broken clamp, you say. If it is the clamp ring that fits over the taper and it is an original JD part, it is made of cast steel and it welds just fine. If it is another brand such as F&H, test the ring by touching on a grinder to see if it is cast steel or cast iron. If the broken part is one of the projections from the hub that has the axle splines on the inside, I am told that the clamp ring holds it in place and for light work such as parades, that is adequate. I have not tried this personally. Epoxy for structural hub repairs- not strong enough.
Bguy
08-09-2003 06:52:48
No, but I have tried welding them without success. If a weld won't hold I can't imagine a JB Weld/epoxy job even beginning to hold. there is quite a bit of stress and pressure put on these parts, even on the show tractors you don't want the wheels sliding around on the axle when loading and etc. I decided to do mine right and replaced the clamp.
