Hopping up a 1950 John Deere R
Some crazy pers
08-08-2003 22:36:03
I have a 1950 John Deere R. I am now the 3rd owner of this tractor. This tractor has been pulling for about the past 20 years. Has had a good run of it. it has consistently performed well in the 8500 and 9000 pound classes. But now it is begenning to show its age "engine". I dont think that the previous owner did much more than turn up the pump and maybe have the injectors done. In a couple of years I am going to tear this tractor down and restore it. and do some "minor" HeHeHe! souping up.I want to get the maximum amount of power out of it. I am going to bore and stroke this tractor as far as is "somewhat sanely" possible. I plan on replacing the pistons with as big as can fit in the new bore and replacing the injectors with something that will be able to feed the beast. Any one have any experience or suggestions with this??? I am begenning to see red and yellow paint go wizzing past. What a disgrace. Someone please help!! I dont want to stain the John Deere name.
fritz
08-09-2003 17:01:43
 Re: Hopping up a 1950 John Deere R in reply to Some crazy person in IL, , 08-08-2003 22:36:03
I have 4 pistons 6.250 cats.I used 2 in my 730.GOOD LUCK.
Big Roy
08-09-2003 08:33:49
Last year I rebuilt the diesel engine on my 51 R, didn't do any major changes. I had the vavle seats cut so it would take 830 valves, new pistons and rings, and bearings. The pumps have been turned up previously. Right now it's putting out about 70hp. If I didn't use the R in the field I would have bored it out to use 830 pistons and injectors.
Adam B.
08-09-2003 02:55:34
I've read/heard that in the early days of the R, there were some crank failures under hard loads. In response to that, Deere changed to a 3-main crank on the following tractors in this line.
That may be a limiting factor to how wild you can get with the R, but you'd have to ask some of the R pullers how far they've been able to push their tractors.
Gpower
08-09-2003 06:47:13
 Re: Re: Hopping up a 1950 John Deere R in reply to Adam B., 08-09-2003 02:55:34
You can get 85-90 out of one without "big" cubes. Everybody says the R is limited due to crank failure, and true it could be, but arent they all?? Ive heard of 95-100 being done, but never seen one on the dyno that high. I built the fuel system for mine, just takes a little time to get the kinks worked out. Good luck
Gpower
Chris in IL
10-18-2003 19:43:27
 Re: Re: Re: Hopping up a 1950 John Deere R in reply to Gpower, 08-09-2003 06:47:13
I have been afraid of breaking a crank in this R if I do too much. Would it be POSSIBLE
to put an 830 crank in an R??? I know that there would have to be a 3rd main put in somehow... any way. Just an idea???? or would I be better off to have a crank built from scratch.
Mike M
08-09-2003 18:16:42
You would have to have access to a belt pulley dyno as the pto in R's could not handle the stock HP let alone that much.
Gpower
08-09-2003 18:52:48
 Re: Re: Re: Re: Hopping up a 1950 John Deere R in reply to Mike M, 08-09-2003 18:16:42
The R pto clutches were not that well designed, I have seen them handle 78 hp before the drive started popping though. TO bad the tractor was not down to rated yet, will never really know what its putting out now.
