Harry, I dont have much experience on the new fangled tractors that had more than just 2 cylinders, but I heard they made them. Anywho, that being said, if its a 24 volt system with two 12 volt batteries in series, their center tie point is also tied to frame ground, one beign one batterys + and the other batteries - terminals. The 2 outermost untied terminals (remaining + of 1 battery and - of other) is 24 volts and thats what goes down to the isolated from frame ground 2 wire 24 volt starter and 2 wire isolated from ground 24 volt generator. Those 24 volt 2 post starters dont use frame ground like a 12 volt starter does that has only 1 post and uses frame ground for the other. Is that the system you have, a 24 volt starter and generator dual series battery system????? If not ignore most of this n post back. Its possible to use dual 12 volt batteries in paralell on a 12 v system, but those would have BOTH + and - terminals wired to the same place. Dual battery series systems need the batteries in series with the + of one and the - of other tied together in the center, then the outermost untied terminals make up the added series 24 voltage. If so (you have a series dual battery 24 v system), the lights and other 12 volt circuits are shared off both batteries, some circuits 12 volts neg ground and others 12 volts pos ground, via A and B battery circuit feeds up to the switch. That works cuz BOTH batteries have an end tied to ground (the center + - series union of the 2 batteries) so its still 12 volts from EITHER remaining outermost untied terminal (one of the two to starter) to frame ground. That way 12 volt lights can still work fed from either untied outermost battery post to frame ground just like an ordinary single 12 volt battery tractor would, the lights dotn care if their feeder battery has its + or - tied to ground. I prefer the 24 volt system for cold weather starting, if you go to 12, you need a 12 v starter and generator and some major re wirign if its 24 now. Even if a 12 and a diesel, I would still use 2 batteries (or 4 6 volters) in paralell for added capacity. Dave Wickman WTW is the go to man on 24 volt systems, he has a link to a post on here where he explained the system in great detail, hopefull he might weigh in here. Again, if you just have a 12 volt system disregard this n post back, but if one is + and other is - to ground as you say, sounds like a 24 volt system. If batteries get low on acid and too much water is added or if they get in a low state of charge affecting the specific gravity, they can fail and freeze up. Keeping acid and having them well charged prevents that. Post back or e mail [email protected] any questions. Good luck n God Bless ya Harry John T Nordhoff
