48 A Clutch
Frank in WV
08-08-2003 05:46:29
I took the clutch apart and now it does not snap in or out and won't hold in. What did I do wrong? I put in new facings. I did pull the pulley assembly off the crank and sprayed the toggles with carb cleaner to clean them up. I repacked the bearing with wheel bearing grease and put some on the toggles and sprayed some lubricant all around. I also greased the crank shaft where the pulley slides on. The clutch did knuckle in and out before but did not release real good. Do I need to run it a little to make sure everything gets well lubricated again? I have it assembled with the facing on the inside, driving disk, facing on outside and pressure plate. The toggles the adjusting castle nuts fit on do move freely.
Clooney
08-08-2003 11:31:00
 Re: 48 A Clutch in reply to Frank in WV, 08-08-2003 05:46:29
Frank, been putting this one off hoping someone else would do all the typing. No such luck..
~Well if it worked before & not now, you either assembled something wrong- [probably not but possible],, or you didn't get the same parts back in the same place-[once those clutch parts wear in they don't always work the same when re-assembled in different places],,or you don�t have an even & proper adjustment.
Start by loosening all 3 adjusting nuts, then engage the clutch, then tighten them all the same with a short wrench or ratchet. After they are all the same tightness ALWAYS do the same for all 3. Adjust from there & see if it will then work ok.
~Once the adjustment is made & the nuts pinned, use a wrench & turn the adjusting nuts until they are centered in their twisting direction �[when you tighten those nuts you also turn the adjusting bolts & that off-sets the T in the pivot behind the pulley causing an improper operation [usually worse with worn bolts & pivots].
~If the above doesn�t help you will have to pull it apart again & see if you can match the proper parts back up using their wear marks or just try the parts in a different location.
~If you still have a problem post back as you will probably need to replace some clutch parts. ~While it�s apart make sure the operating sleeve drive pin & pin hole in the operating sleeve isn�t worn & allowing the operating sleeve to rotate. That alone will keep the toggles from properly going over center..
