JD 50 PTO Slips
Larry B
08-07-2003 19:06:54
The engine driven pto on my 50 slips whenever I load it at all. Also the pto shaft is really loose and wobbley and leaks oil steadily when engaged. I am preparing to disassemble the unit and have read the manual several times but still have a few questions. 1) Once the main pto cover is unbolted and the clutch linkage is disconnected does the unit just pull out and disengage from the clutch fork? Do I have to worry about the shaft coming out of the engine drive gear and the gear or some other parts falling into the bowels of the transmission. Do I need to drain the recently flushed and refilled transmission or are the cases sealed independently?
2) When I disassemble the clutch pack how do I determine if the clutch disks are OK to reuse or need to be replaced?
3) Does the pto shaft float on only one outer bearing or is there also an inner bearing or bushing. And are the bearings in the unit pressed onto the shafts and are the races pressed into blind holes (Do I need special tools)?
4) Manual says to use motor oil in the unit, JD dealer says to use Hy-Gard hydraulic oil, who is right or does it matter.
5) Lastly once its apart can I drive it a short distance out of the shop while waiting for parts or should everything remain static until reassembled?
Mike M
08-09-2003 18:35:09
 Re: JD 50 PTO Slips in reply to Larry B, 08-07-2003 19:06:54
If you see any evidence of gear lube in the pto
you better go the distance and pull the back off the tractor and replace the pto pump oil seals.
