JD 1010 serial no. and utility Q on scoop bucket
Lee
08-07-2003 05:16:45
Hi all, can someone help me confirm year for this serial no? 1010RU25230. I am considering buying this tractor. It's complete restored. Very clean and runs good. The seller says it's a 1964 but I thought if so I'd see serial number like a 43900. He's 2nd owner and was told it to be a 1964. He doesn't have operator manual. Where will I get one of those?
Another question. Has anybody had successful experience with attaching one of those pull behind scoop buckets, as an alternative to front loader? If attaching to the 3 pt, can it be inverted such that you can back into the pile and scoop, as opposed to having to pull forward over and through the pile to scoop?
I'm a hobby user, having used a Farmall Cub previously around my woodlot to do some light/ heavy chores. I can't seem to afford the prices of tractors in any good shape that include a front loader. Thanks. Lee
firedog
08-07-2003 20:19:05
 Re: Re: JD 1010 serial no. and utility Q on scoop in reply to ron, 08-07-2003 19:59:59
Check your points, cap, and rotor button. I used to get a lot of moisture and it would tarnish the contact surfaces to where the spark was weak. You might want to consider electronic ignition for that tractor. It was a cold hearted SOB.
firedog
