H clutch, reporting back - Clooney
leon
08-06-2003 19:15:02
Some weeks ago Clooney, you suggested taking about 0.20" off the face of the operating sleeve on my '41 H to get the clutch dogs to go over center. You mentioned that you'd not tried it on an H, but that approach worked on other models. Well, it works on an H too. Only thing, I had to take 0.40" off. I can't be sure the clutch was all original matching parts when I started, so perhaps that's why I had to take so much off. Thanks again for the help. As usual you were right on!
Clooney
08-07-2003 03:37:33
 Re: H clutch, reporting back - Clooney in reply to leon, 08-06-2003 19:15:02
Leon, glad you have it up & working. That .040" does seem like a lot to machine off but if that's what it took to get the toggles to go over center, stay there, & still be able to un-snap, that's what it takes. I had to go that far on an old B once. ~How does it feel when dis-engaging the clutch? As long as the clutch doesn't slip under load & can be released without great amounts of force on the hand lever .040" is the correct number for your operating sleeve.
~Thanks for the follow up....
leon
08-07-2003 04:04:23
 Re: Re: H clutch, reporting back - Clooney in reply to Clooney , 08-07-2003 03:37:33
It now snaps in really nice and disengages with about an equal amount of force. I left it a little on the loose side so it won't be so hard to use for the grandson, still it doesn't slip under full load. The funny thing is that there didn't seem to be all that much looseness in the linkages. Guess it just all added up. Satisfying job - but that's why we work, play, with them isn't it!
