Hey there Budd, Well, I will say right off Im sorry cuz I cant give you the simple answer youre looking for, but will still try my best to help you. The reason I can not give a simple answwer, is because I have no way of knowing if your coil, for one has an internal ballast, and if so, where it is physically wired inside. I am of the opinion (clooney and I shared e mails discussign this long ago) the ballast should be wired on the battery input side AND NOT between the primary output and the points and condensor, but not knowing where its at is the reason I cant definitely answer your question. However, I will take my best engineerign guesses and assumptions and tell you how I would wire it and why. 1) My best guess, since you say its a 45,000 volt coil, is that its for a high performance type auto ignition which is negative ground, and to be safe, I would wire it neg to the distributor. HOWEVER if I knew for sure it had no internal ballast (like if its near 3 ohms total with primary winding resistance only and no ballast), then I would wire it + to distributor which is how you wire an unballasted coil (like a 6 volt non internal ballasted coil) at pos ground. I CAN ANSWER YOUR SECOND QUESTION BETTER. 2) You asked how many "volts" on the distributor, but thats not the right and valid question, cuz the distributor is a current (not a voltage) device that is a mechanical switch (points) which closes the conduction path so the coil can conduct current to ground when points are closed, then open the path when the points are opened. The correct question is how many "amps" can I allow to pass through the distributors ignition points (mechanical switch). The basic answer (how much current through distributor) so the points do not prematurely burn out is around 4 amps give or take. That means on a 12 volt system, the total resistance of the coil plus any ballast (internal or external) is around 3 ohms. Some 12 volt JD's used a 6 volt coil (around 1.5 ohms) and a series ballast resistor which drops 6 volts leavign 6 across the coil as it was designed for. The voltage at the distributors input (lil side hook up terminal where coils primary output wire attaches) would be 6 or 12 volts (dependign if 6 or 12 v battery) when the points are open, then drop to zero when they are closed, since the points closing makes that point a dead ground. So, the disributor is basically the same, regardless if a 6 or 12 v battery, and its just a open/close current switch with the input voltage dependant upon what the battery voltage is. I hope this un cornfuses you some Budd, post back or email any more questions. Good Luck 2 ya and God Bless John T Nordhoff in Indiana
