G water leak
Duben
08-06-2003 15:44:53
Every since I rebuilt the motor on my G two years ago, there's been a small leak that looked like the drain plug was leaking. It's a bit worse now (although just a small amount can be seen on a concrete floor) and it appears that the water is coming from the lower two head bolts. Any idea what the cause would be? The water is green antifreeze and the tractor never smokes.
Dale
08-07-2003 11:35:45
 Re: G water leak in reply to Duben, 08-06-2003 15:44:53
When I first had my G and put a head on it, it leaked like yours, only just while working. I finally had to replace the head bolts themselves as they will stretch with hard use. At that time(around 1988) they were available from Deere for around $14 each. Good luck. Dale
