4630 Quad Range Shift Problem
Paul Butler
08-06-2003 09:35:52
I just bought a 73 4630. The only issue I have is the 2nd shift lever (ABCD one) just falls through from A to D.
If I hold it in place with my hand all the gears are fine but as soon as I let go of it the thing drops.
I haven't dug in or got my service manual yet (ordered) but anyone else seen this issue?
WTW
08-06-2003 10:12:21
 Re: 4630 Quad Range Shift Problem in reply to Paul Butler, 08-06-2003 09:35:52
Paul, There is a spring that supports the weight of the range shift arm that is broken and or missing. This spring attaches to the lower shift arm clevis pin on the right side of the transmission case below the cab. It extends up to the cab floor where there is a hole drilled in a iron that is under the cab floor. The part number for this spring is R56776. Without this spring the weight of the shift cam on the inside of the transmission well allow this to happen. Most likely there is nothing more wrong than this spring. Good Luck Dave W.
Paul Butler
08-06-2003 10:37:37
 Re: Re: 4630 Quad Range Shift Problem in reply to WTW, 08-06-2003 10:12:21
Thanks for the quick response and part #!!!
Looks like it should be a "Snap" to fix.
Paul
