2010 3 pt won't lift
Terry
10-20-2003 17:51:38
My boss gave me a 2010 and the 3 pt won't pickup, they were using a bushog from a larger tractor on it and it seem that it was just to much weight for the smaller tractor and the hitch just quit working any thoughts on what might be wrong. Sorry for the lack of info but I don't have the tractor home yet, Just trying to do some prelimanary trouble shooting. Thanks....Terry
M Young
10-21-2003 08:24:31
 Re: 2010 3 pt won't lift in reply to Terry, 10-20-2003 17:51:38
I had a similar problem, Start by checking the fluid level, then flush the system with kerosene, and change the hydraulic filter! dont try to clean it just change it, it will save you a lot of headaches down the road. Good Luck
Tom
10-20-2003 18:10:54
I had trouble with my lift after an oil change. I opening the gear case cover (under the seat) during which I heard a belching sound; it still didn't work. But when my daughter decided to manually pick up the lift a few times and I tried reving the engine, it started working. I think it must have had air trapped somewhere and my daughters' "hi tech" jiggling loosened it up.
I've also heard from this forum that the filter clogs on these tractors, so you may want to try a replacement ($66 from JD).
Tom in Mo.
10-20-2003 18:10:01
Probably your first investment should be in the John Deere factory service manual. It is very complete and covers everything about the tractor. The manual # for your tractor is SM-2035. Your Deere dealer can get it or you can order by calling 1-800-522-7448.
