JD 50 starter won't always engage
RandyG
08-06-2003 07:33:06
I had the starter on my 1955 JD 50 reconditioned and for some reason it won't always engage.I have adjusted the starter push rod all the way out but it will not push the new starter switch in far enough to engage the starter all the time. It did this before the starter overhaul too. Please give me a direction to start to fix this problem!!
Thanks for any help!
Randy G
ChuckW
08-07-2003 04:56:01
 Re: JD 50 starter won't always engage in reply to RandyG, 08-06-2003 07:33:06
the contact must be bad on your starter. I alwasy put a new switch and also have the button/contact on the starter replaced. They may have not replaced this when rebuilding. It's hard to do as an individual if you haven't had a lot of experience and there are some special spacers/insulators. Also on the 50 a resistor by pass contact should be on the starter switch. A wire goes from them to the distributor side of the resistor and when you crank, you get a full 12 volts.
Bob K
08-06-2003 13:55:17
I found the contacts on the starter button melted down pretty far on mine requiring greater travel of the pedal before energizing the starter motor. I had to stomp hard on it to get that last needed few thousandths to make contact. I replaced the starter button and my problem was solved. Had to reposition it on the starter housing a couple times to get the linkage right, but it works good now.
JDMark
08-06-2003 11:03:21
I have the same problem on 2 B's. What happens is that the lever actually hits the edge of the opening in the main case before the button gets pushed enough. All parts are new, so it's not because of worn out parts. I turned a "cap" on the lathe and pressed it onto the switch button, giving it a little extra length. On the other one, I welded a little tab on the starter lever where it pushes against the button.
Seems to work OK
Randy G.
08-06-2003 14:41:41
 Re: Re: JD 50 starter won't always engage in reply to JDMark, 08-06-2003 11:03:21
Thanks for the ideas guys!!! It does have a new switch. What I may try is JB welding coins to the switch button, I have no welder or lathe. I've heard good things about JD Weld. If it doesn't work I will take the starter to the welding shop and have a bead put on the lever that pushes the switch. I've had the thing off and on 4 times in the last week and will try JB first before pulling it again.
Thanks VERY MUCH! I now have options.
Randy G.
Mike M
08-07-2003 05:16:04
 Re: Re: Re: JD 50 starter won't always engage in reply to Randy G., 08-06-2003 14:41:41
I was working on a 50 at some ones house they had no welder to build up the lever that pushes the button and I also was tired of pulling that starter on and off. So I just slipped the end of a cresent wrench the one with the hole, over the
lever and bent it up a little to push the switch more. It bent pretty easy and has been working for a long time now.
ron in MN
08-06-2003 07:56:15
Is it not making mechanically or electrically or both? I find that I sometimes need to stand up and push down really hard on mine to make the electrical contact work. Was it reconditioned on both the electrical and mechanical?
Randy G
08-06-2003 08:21:25
 Re: Re: JD 50 starter won't always engage in reply to ron in MN, 08-06-2003 07:56:15
It was reconditioned completely, new bendix, brushes, bearings etc. The bedix pushes out but the switch is not pushed in far enough to engage motor all the time.
