JD 410 - Removal of Tapered Pins Bushings
Jon
08-06-2003 05:15:40
Got a nice old JD 410 backhoe with nice old (worn) tapered pins and bushings in the backhoe swing arm assembly and I'm trying to get the them loose for replacing. I have the JD Tech Manual that talks of fashioning a puller device using a bolt threaded into the pin. I've tried that, including hammering on the the bolt to shock the bushing loose - no luck.
Any tricks of the trade out there that produces results? These are good sized bushings - 2" OD, 1" ID or something like that. I've got torches, but I really don't want to use heat if I don't have to.
Thanks for the help...
Jonathan
08-06-2003 14:30:38
 Re: JD 410 - Removal of Tapered Pins Bushings in reply to Jon, 08-06-2003 05:15:40
Are the tapered bushings protruding above the casting ??If so some solid strikes with a large pin and hammer at 90 degreees to the pin on the side of the bushing tends to draw them in the direction of the taper...
