4010 PTO
Steve Ga.
08-06-2003 04:03:26
been using 4010 on 10 ft. bush hog for several years with no problems,yesterday the pto just quit.when i checked the pto shaft was loose(and 2 bolts were gone)i removed the stub shaft and replaced,like the book said,able to push the pin in,but still nothing,it does turn without the 540 stub on.have i lost it or is there something else to check?does the tractor have to be split to repair
Jim B
08-06-2003 04:42:35
 Re: 4010 PTO in reply to Steve Ga., 08-06-2003 04:03:26
Steve,on PTO on 4010 the rod that the 540 stub shaft pushes in for 540 rpm's moves a small pin way inside trans.This small pin can bend or break not allowing engagement of the 540 rpm speed.If pin is broken the tractor has to be split between trans. and diff.If split and you only use 540 I have changed several to 540 only by removing collar that uses small pin and installing a larger bolt to hold pto in 540 only.Cured small pin problem on 3010's and 4010's.This is one of the problems JD solved on 3020's and 4020's.Split with caution.The reason pto turns without 540 stub shaft is it's turning at 1000 rpm's at engine pto speed if I remember correctly
