70D fan shaft question
Ty
08-05-2003 19:41:40
I have a 1/4" gap between the fan tube and the bevel gear housing on the gov. It has power steering. I redid the pump and had the books for it. The shaft out of the pump where the bevel ends and the splines start is flush with where the fan tube gets connected to. I have proper heel of the bevel gear so that the housing to gov shimming is good. I had to get a shaft for it has no part number but should be the same even if it did come off a 720 or 30? It is for a std.serial 7022900. I also have a row crop w/ power steering and fan tube length is the same as well as the fan end of it also. Should I just take it to a machine shop and cut a little off each end? Can't find a prob with any ends. There is plenty of spline to grab so I don't think it would be a problem.
F-I-T
08-05-2003 21:47:38
 Re: 70D fan shaft question in reply to Ty, 08-05-2003 19:41:40
Ty:
There was a serial number break on the 720 Dsl P/S fanshaft. I don't know what the design difference was. It could have been length. The shaft used on 720's upto S/N 7214899 would have used the same shaft as your 70D. That part number change could be the difference.
Frank
