H Carb
Donny-B
08-05-2003 19:13:17
Can anyone tell me what year the DLTX 26 was replaced by the DLTX 46? I have a 41 H with hand start and a DLTX 46. Should it have a 26? Thanks in advance.
Duane Larson
08-05-2003 21:06:36
 Re: H Carb in reply to Donny-B, 08-05-2003 19:13:17
Donny-B,
If your H is hand start, it should have the DLTX-26. When the electric start became available (s/n H27000), the DLTX46 became standard equipment. The only difference between the two is in the choke lever (it allows operation from the driver's seat) and the choke plate - the 46 has a spring-loaded opening in the choke plate so the electric-start tractor would not choke out until the choke lever got pushed in, and the 26 has a solid plate.
The JD carb manual has several errors in it, and that is likely where the confusion about all-fuel and gas comes from - and has been propagated on several web sites. There never was a gasoline version of the H - (but you could burn gas in it, of course).
John T
08-06-2003 07:04:58
 Re: Re: H Carb in reply to Duane Larson, 08-05-2003 21:06:36
Thanks Duane, my book of info is the Roberts Carb book (not off the net anywhere) and I sure dont bet its all that accurate lol. See you next Marh at GOG ???? John T
dan_41jdh
08-06-2003 05:59:25
Duane,
a very minor clarification - the DLTX-46 became standard equipment after s/n 27000, regardless if the tractor was equipped with electric start or not. The provision for optional electrics (offered three ways - starting, lighting, or starting and lighting) was a mid-year change introduced during the "H" 1941 model year. And, there were lots of H's built without electrics after s/n 27000 even though that stuff was available. So, it'll depend on Donny-B's serial number as to which carburetor it originally had. Hand start doesn't necessarily indicate it should be a DLTX-26. However, I believe Deere offered the -46 as an "official" replacement part for either carburetor in later years, since it is (downwardly) interchangeable. And, you are dead-on regarding the confusion and erroneous information about "gas" and "all-fuel" versions of those carburetors.
Duane Larson
08-06-2003 16:12:30
 Re: Re: Re: H Carb in reply to dan_41jdh, 08-06-2003 05:59:25
dan 41jdh,
I had meant to convey that fact, but it was not stated clearly - you are exactly correct - once electric start became available, the DLTX46 was used on all Model H's, both electric start and hand start.
Donny-B
08-06-2003 16:01:40
Dan, My 41 hand start is serial #37126. It came with a DLTX 46. Just wanted to know if it was original for that year.
dan_41jdh
08-06-2003 17:13:27
 Re: Re: Re: Re: H Carb in reply to Donny-B, 08-06-2003 16:01:40
Donny-B,
Your H, s/n 37126, should have had a DLTX-46 as original equipment. But, here's a little surprise - - your tractor is actually considered to be a 1942 model. Although I'm guessing your tractor was built in August 1941, it is considered a 1942 model. My H is about 800 units later than yours and was built in late August 1941. I have a letter from Deere dated 1975, that stated mine was "manufactured during the 1941 product year". However, J. R. Hobbs and others have researched things more thoroughly since that time, and have concluded with confidence that the beginning serial number for the 1942 model year H was 35699. So, I guess that makes both our H's 1942 models! (Reference: Green Magazine, December 1996, and the current Two-Cylinder Club beginning serial number list). There are a lot of printed and internet sources that still show the old beginning numbers which were originally compiled in 1976 by Deere people. However, they are inaccurate because of some confusion between model years and fiscal years. The model year of H's is probably mostly academic interest anyway, because very few significant changes to the H actually coincided with model year changes, no matter if you use the old list or the new list.
Donny-B
08-07-2003 15:44:05
 Re: Re: Re: Re: Re: H Carb in reply to dan_41jdh, 08-06-2003 17:13:27
Dan, Thanks for the info. I enjoy finding out all the history associated with a tractor I own. According to Deere's archives the warehouse date on my H is 8/8/41. I will send for a copy of the December 96 issue of GM to show with my tractor when restoration is finished. Thanks again.
dan_41jdh
08-08-2003 14:58:20
 Re: Re: Re: Re: Re: Re: H Carb in reply to Donny-B, 08-07-2003 15:44:05
Donny,
I should clarify that the article in the Dec '96 issue of GM discussed the serial number/model year issue, and was not specific about the model H tractor. GM had a feature article about the H in the May '96 issue. Also, Two-Cylinder featured the H in the Mar-Apr '99 issue. Another good "H" reference is J.R. Hobbs'
book entitled "The John Deere Styled 'Letter' Series, 1939 to 1952". However, it contains most of what the May '96 issue of GM had about the H.
Paul from MI
08-05-2003 19:50:41
My H #20694 has the older DLTX 26 carb. What is your serial #?
Paul
John T
08-05-2003 19:23:01
Donny, Im not much on an H or a D, but I think its not so much of a year issue as it is an all fuel (DLTX 26) versus a gas (DLTX 46). My book shows SN H1000 and up tok the 26 if all fuel and 46 if gasoline. What fuel(s) are you running??? If gas only, the 46 should do fine. John T Nordhoff in Indiana
