Drive disc instalation
Lincoln
08-05-2003 18:35:02
I pulled the drive disk out of the clutch on my A. Like a dummy I did this before marking its location on the crank shaft. What will happen if I don't get it back in the right spot?
Or better yet how do I get it back in the right spot? I can see the ^ on the disc but not the crank.
Clooney (drive disk inst)
08-06-2003 03:32:45
 Re: Drive disc instalation in reply to Lincoln, 08-05-2003 18:35:02
Lincoln, you ask "What will happen if I don't get it back in the right spot"? Answer,,, the engine will vibrate..
~To install correctly: just turn the flywheel until the L/H impulse writing on the flywheel is at the rear & the slots in the flywheel are parallel to the ground then install the clutch drive dick with the heavy part directly towards the tractor's front�. OR, if you have a covered flywheel, pull the R/H spark plug & use a wire or pencil & feel for the piston, then rotate the crankshaft until the R/H piston is at exactly TDC, then install the clutch driver with the weighted side directly towards the tractor's rear.. ~Once it�s on correctly, mark the clutch driver hub & crankshaft so you won�t have a problem next time..
John T
08-05-2003 19:13:51
Lincoln, if you cant find the crank match for the clutch disk V mark you mentioned, the heavy side of that clutch disk MUST BE EXACTLY 180 opposite as the heavy side over on the flywheel, or its VIBRATION CITY. Good Luck, John T Nordhoff
Ellis Brasher
08-05-2003 19:01:38
The repair manual says "The V mark on the drive disc should be in register with flat spot at end of one of the crankshaft splines".
I'm rather sure that the HEAVY side of the drive disc should be on the opposite side from the crank throw on that side of the engine so as to provide balance.
