Attn:John Deere G nut,G Man,Clooney
Dave
08-05-2003 17:47:14
Have sheared rivets & washers in pinion,gear to center spider.What do you do to eliminate this problem? Also starting to slip in bull gears.This is a 1952 John Deere G.Appreciate any advice you can give me.
Common Problem Easy Fix
08-06-2003 08:01:15
 Re: Attn:John Deere G nut,G Man,Clooney in reply to Dave, 08-05-2003 17:47:14
This is very common on any "G" puller with some power potential. The one and only final fix is to get the gear centered back up on differential carrier if it off and stitch weld bull gear to carrier. This can be done without removing gear or differential from the tractor. I have seen several do this and have never seen one fail again after welding it. Nothing to loose as the carrier and gear are both screwed up anyway.
Clooney
08-06-2003 03:38:54
Dave, I have only had to address this problem once as I'm not a tractor puller. On the one I had I lined the original holes back up installed more production rivets & washers [not sure they are still available]. Then drilled added more rivets & washers directly between the originals. That repair is still holding 20 years later.
~If your gear has been spinning & it, or the gear carrier is worn you might have to take a different approach.
DP
08-05-2003 19:58:55
Hi Dave. Had the same thing happen on my 46 GM. Talked to an old retired John Deere mechanic about it. He said the 4020's had a similar problem develope. Their answer to the problem was to get the grooves lined back up and put in new dowels, then half way between the existing dowels, drill another hole. Then get three more dowels, one size bigger than the holes you drilled, (use a soft steel), and drive them in place, triming them to length when done. I've pulled mine several years since with no problems. Good luck to you! Don
Ellis Brasher
08-05-2003 19:26:07
Have you considered drilling some dimples at the parting line and then welding in the dimples. I would think about maybe a dozen on each side. I assume the gear teeth are a high grade steel and the inner part is cast iron or cast steel. Not knowing the very best weld rod for this application I would consider 310 stainless and probably preheat to about 200 degrees.
Rich
08-05-2003 18:19:04
There is a puller called Burns that had this same problem on his G, I think he talked about on this board. You might find it in the archives.
