Electronic ingition?
JDJACK
08-05-2003 14:37:45
I have a 3020 gas 12 volt with generator.
I would like to convert this from points to electronic. Not positive if it is neg or pos ground. Where can I purchase this kit, what all does it require to do, and about how much does it cost? Thanks in advance, JDJACK.
ChuckW
08-06-2003 05:03:12
 Re: Electronic ingition? in reply to JDJACK, 08-05-2003 14:37:45
JDJack, I have put 7-8 of these units on. It is the best move for a tractor since 3 point. From the guideline from Genesee they should kits for 1010/2020 using positive or negative ground and using prestolite distributors, don't see 4020 but you can call Andy at 918-274-8000 and if they have it he will help. The coil and distributor setup is about $130.00. Personally I can't say enough about it. You can flood a tractor and the spark is so hot it will fire right through it. Also the type plug (hot-cold) is not much of a factor. You're using about 40,000 volts vs about 25,000 now. Good luck.
S. Conner
08-05-2003 23:18:42
I have installed two of these electronic ignitions and am amazed at how simple it is and how well they work. One I put on a 4010 and the other on a 580 Case backhoe. Go to www.vintageperformance.com. Their prices are cheaper than the other place and shipping is free, at least it was the last time I ordered anything. Pertronix is the manufacturer of these kits. Get the 3 ohm coil for a four cylinder engine. It's around a hundred bucks for a kit with a coil. Look at your battery and whichever cable is connected to the transmission housing is your ground. It should be positive ground unless it's been converted.
Ralph Ia
08-05-2003 18:57:16
Jack go to geneseeproducts.com Andy is the guy to talk to. He is so helpful.
John51
08-05-2003 15:06:53
Should be negative ground. I did this with a 4020 gas, good results. Basically its a matter of pulling out the points ,etc and replacing with the electronic module. It's an easy and quick job. Have to set the timing when you're done. I'll look at the name of the one I bought and post it later.
