Hey G Guy, lets discuss a few generator and Volatge Regulator issues first. 1) If you installed a new VR at negative Ground, is it compatible for negative ground tractors????? Some will work pos or neg grnd, others will not. Once it was installed, did you polarize the gen by momentarily flash jumping a wire from the VR's BAT terminal over to its ARM (or GEN) terminal and get a spark???? 2) Is it a 3 wire (BAT,,,ARM,,,FLD) or a 4 wire (BAT,,ARM,,LOAD,,FLD) VR ????? On many 4 wire VR's, the ARM terminal is off on 1 side by itself or off the bottom. It had a 3 wire originally, but changes can happen over the years. 3) I ask that cuz you mentioned a wire from the light switch to the generator????? ??? Whats that all about and wheres it wired to on the generator????? ? or on the VR ????? 4) A 3 wire VR should be wired: BAT terminal to the load (non battery) side of ammeter. That load terminal also feeds lights and ignition etc while the ONLY wire on the other (Battery) side of the ammeter is the one to the starter post and its always hot. Also, the wire to the BAT terminal on the VR is always hot, so the generators output can get to and charge the battery. BOTH ammeter terminals should show battery voltage at all times. ARM (or GEN) terminal to the ARM (larger of the 2) posts on the generator. FLD terminal to the Field (smaller of 2)posts on the generator. 5) If you have a 4 wire VR, those are the ones that feed the light switch off the LOAD terminal instead of them being fed off the load side of the ammeter as above. I assume youre at neg ground cuz of the elec ignition right????? Once you verify the gen and VR wirign and check if your VR works on neg grnd, and youre wired right for neg ground, I will look into the backfirign problem, but I dont see how you would have changed any timing or got any ignition system wires messed up by just working on a new VR????? ? Unless you got the plug wires crossed??? Even if she didnt charge, if youre at neg ground and no wires were changed nor timing, Im not sure yet what the problem is,,, did you reverse the ammeter leads to make it read right when you went to neg ground????? ? Cuz it still has to have just 1 wire on the battery supply side and all others including lights and ignition and the one to BAT on the VR on the other load side. Many of those elec ignition just have the 1 wire to the ignition switch or coils high input side (voltage source) and the other to the coils low (to distributor) side terminal for its ground path, is yours like that and wired right????? When you turn the ignition switch on, does voltage appear at the coils input side??? It has to to work, use a test lamp or voltmeter to see. Also, if you place a test lamp on the coils low (to distributor) side and turn ignition on and slowly the crank engine over, the lamp should go on and off as the elec switch opens and closes to conduct or open the ground path for the coil. See if it does???? Besides change the VR, did you do anything else and she ran before but will not now????? ? Cuz you cant just reverse wires on that like on the Wico C and X mags if they are 180 out of time you know. (It shouldnt have got out of time just seting) HOWEVER, if they (plug wires) are on the wrong terminals, she wont run and can backfire. You might bring the left cylinder up to and and just past TDC on its compresion power stroke and see if its plug fires then with the right cylinders plug firing 180 later????? ????? if NOT, see if a wire reversal makes that happen, cuz thats what she has to do to run. CAUTION, if you crank her over with the plugs removed to see if they are firign at the right time (TDC on power sroke) be sure the plugs cant ignite any raw gas spewing out the plug holes. NEW CARB QUESTIONS Have you adjusted the new carbs top load and idle needles (1 out load 2 out idle)?? Is she getting gas??? Any black smoke out the stack??? Are the plugs wet or dry after she dont start??? Shes not gas floodign is she????? Is the choke butterfly plate actually opening and closing??? Theres no vacuum leaks at the new gasket are there????? Theres sufficient gas to and filling the carbs bowl right??? If you open its lower drain cock/plug, does a 1/16 inch gas stream run out continuous??? Gas dont over flow out the carb does it???? Do some of this and let me know what you find and hopefully its something sipmle like too litle or too much gas or mis wired somewhere. Good Luck n God Bless John T Nordhoff in Indiana
