Blade for JD 70
Scruffy
08-05-2003 13:51:04
Can someone tell me if John Deere made a blade that fit the John Deere 70's rocker shafts? I'm hoping to find something for my JD70 to use for plowing snow. It'll be more of a backup setup as I have another tractor with a 7ft 3pt blade.
I had originally planned to put a 3 point on my 70 as well but I am reconsidering. My uses for the tractor are splitting wood, pulling trees, pulling brushhog, and putting around. I have long lane to the mail box : )
So I really don't have a need at this time for it to have a 3 point. But I'd like to add snow plowing to its list of chores if anyone can help me.
thanks,
scruffy
Mike
08-06-2003 17:57:04
 Re: Blade for JD 70 in reply to Scruffy, 08-05-2003 13:51:04
I have a dozer blade built for a 70 ,but it's shop made but looks good very strong,It's located in Sw Okla.if your interested. Thanks Mike
Scruffy
08-07-2003 06:53:59
 Re: Re: Blade for JD 70 in reply to Mike, 08-06-2003 17:57:04
Thanks for the offer. I hope to go to some sales here and see what's around. Sw OK would be a hike from where I'm at. But I'll keep your offer in mind.
Thanks,
Scruffy
MIKE HANLEY
08-05-2003 19:52:37
Nothing comes to mind that was factory for the back end. JD's answer to snowplowing in the 1940's and 1950's was the ABG-90 front mounted snowplow for the A B G/50 60 70 tractors that run off a cable lift from thr rockshaft. They came out with a smaller front mounted model when they came out with the "M". Thier first rear mounted rear blade was a toolbar mounted affair that they came out with for the "40" tractors. The first true rear blade was the 80 rear blade when they came out with the 20 series tractors in 1956.
Scruffy
08-06-2003 06:40:05
 Re: Re: Blade for JD 70 in reply to MIKE HANLEY, 08-05-2003 19:52:37
Thanks for the info and history. One question, did the "80" rear blade mount on the rockshaft or was it a 3pt attach?
I had seen a picture of a rear mounted rockshaft blade and didn't know if it was original JD designing or a custom job.
Thanks,
scruffy
MIKE HANLEY
08-06-2003 08:55:29
 Re: Re: Re: Blade for JD 70 in reply to Scruffy, 08-06-2003 06:40:05
What you saw must have been a custom job. The 80 was a rear blade for a 3 PT. That tool bar affair for the 40 tractors was a 3 PT mounted tool bar and the "rear blade bolted to the tool bar. Glad to help.
