A few weeks ago, my fuel gauge began showing "Full" all the time. My daughter told me that this was great, because I'd never have to buy diesel fuel again ! Cute kid....Tonight I pulled out the dash to troubleshoot my ammeter/voltage regulator problem, so I thought I'd look into the gauge issue. It's the ORIGINAL gauge, so it's seen it's share of rain/sleet/snow etc. Hood is on the tractor for now, so I'd like to work this from the dash side. VOM says the sender is at 9.5 ohms. I'll put some more fuel in it and see how that changes. I'll use the calibrated stick device for validation. On the gauge, it has no reading without power, and "F" with power. It reads "F" whether the non-powered terminal is hooked up or not (!?!). I hooked a lead to the non-powered terminal, and grounded it direct to ground, and later through a 10 ohm, then a 25 ohm, 50 ohm , and 100 ohm wire-wound resistors (in that order), and it always reads "F" with power. Is this a bad gauge ? I think it is, but most times I hear about them, bad gauges don't read at all. I am filled with confusement. Frank
