GP Drive Chains
S. McDevitt
08-04-2003 19:52:55
How do you check the drive chains on a '34 GP? We have used it over the years but not much for the past 20 or so. It runs well but we have heard we may need to make some adjustments before we have some major problems. Have other GP owners had drive chain problems? Do all GPs have drive chain problems at some point? Where can we find information on how to check/fix the chains? Thanks Steve
Eric Horne
08-07-2003 07:25:19
 Re: GP Drive Chains in reply to S. McDevitt, 08-04-2003 19:52:55
When I restored a 29 GP, the only problem I found with the drive chains was that they had streched. This allowed the chain to rub knotches in the final drive case. This lead to a bunch of cast iron filings in the gear oil.
Duane Larson
08-05-2003 06:12:49
S. McDevitt,
I would check with Paul Ostrander - they have a website at www.johndeeregp.com and are hosting a GP rally in September. I have GP's, and have not heard of chain problems - the rear axle bearings should be adjusted, but the drive chains have such a short free length that it should not be a problem. The service manual does not address the free length.
Marty Z
08-04-2003 23:51:10
Hey S. McDevitt,
Don't know if you will find much help on GP's here. Seems like no 0ne has them. I have 2 in parts and am still working on them. Both are in sorry shape. I watch for posts on them but I see very few. Sorry I can't help with the answer for this one cuz I havn't tackled the final drive for mine yet. GP seems to be an orphan tractor. One thing I can say is they seem to be much like other unstyled John Deer's . Must use common sense and always ask your self what is the part meant to do. On My D I try to get an inch to an inch and a half slack up and down at the middle piont between gears on final drive. Then rotate the drive to make sure it does not bind at any point.
Marty Z
Curtice Ohio
S. McDevitt
08-14-2003 18:54:45
 Re: Re: GP Drive Chains in reply to Marty Z, 08-04-2003 23:51:10
Thanks for the info. I appreciate the suggestions.
S.McDevitt
