'53 JD 60 water pump questions again
Doc
08-04-2003 19:41:07
Hi Guys,
Thanks to gwh, F-I-T, and Tyler-MO for answering my last post. I checked the old boy tonight. Serial number 6023080. We pulled the water pump last week. It has the original housing (A4280R). Can I just get the pulley pressed out after ordering the slinger, washer, seal (AA5580R) and new bearing (what's the part number on that?) and have a the machine shop put the new one in? This can be done at any auto machine shop that has a press? The best place to order this stuff? Deere? As you can tell, I'm still a novice. Thanks for your help, again.
Regards,
Doc
Mark
08-05-2003 17:16:26
 Re: '53 JD 60 water pump questions again in reply to Doc, 08-04-2003 19:41:07
Call Hy-Capacity in Humboldt Iowa 515-332-2125 They have rebuilt units on hand.
gwh
08-04-2003 21:26:58
Doc, And again think- pulling off the pulley not pressing it off by pushing the shaft and bearing down thru the housing. gwh
Doc
08-05-2003 20:26:55
 Re: Re: '53 JD 60 water pump questions again in reply to gwh, 08-04-2003 21:26:58
gwh,
What's the best way to pull the pulley off without breaking anything? Also, are the rebuilt pumps cheaper than doing this myself?
Thanks,
Doc
gwh
08-05-2003 20:51:11
 Re: Re: Re: '53 JD 60 water pump questions again in reply to Doc, 08-05-2003 20:26:55
Doc, I have access to a puller used for pulling older automotive axle and diff. side bearings, it is a bolt together 2 piece tool, support the tool in a press w/the rest of the pump hanging and push down on the shaft. It also has provisions for screw in puller legs to use w/a cross bar and jack screw. I have no current prices on rebuilt pumps, all the parts I have needed came from Deere and were cheaper than any rebuilt at the time. I have done my model 50, 60 and a '52A for my self and put together my spare for a friends 60 w/no problems. Access to tools and a bead blaster are a big plus. It's kind of like rebuilding domestic use shallow well water pumps did enough of that while growing up at home. gwh
Chris Curless
08-07-2003 12:18:24
 Re: Re: Re: Re: '53 JD 60 water pump questions aga in reply to gwh, 08-05-2003 20:51:11
I just rebuilt my waterpump Monday. I have a 60 also. We have a local shop here in Grand Rapids that does antique car pumps so I went down and asked them if they could do it. $75.00 and it was done. How much is your time worth?
F-I-T
08-04-2003 20:32:19
third party image
Doc:
First, the shaft/bearing kit for the early water pump is AA5579R. JDParts.com shows it available at $55.32 . Generally that price is a little less at the dealer.
Next, Yes, you can press the pulley off, THEN you remove the snap ring (red arrow). VERY IMPORTANT !! This has to be be removed before you press the shaft/bearing out or you risk cracking your pump housing.
I did this pressing with my bottle jack and jacked against the drawbar frame on my 70D. So, yes, any decent shop can do the work. Just warn them about the snap ring.
Send me your e-mail and I'll send you some illustrations if you like. Your e-mail is blocked.
Frank-in-Tallahassee
70D // 855
