3020 Hydraulic
Rick
08-04-2003 19:02:53
The hydraulic pump on our 3020 is putting out a low rumbling noise. The sound "cycles" at low RPM. The remote and loader still work. We recently replace the lift pump because of low flow/pressure. Any thoughts? How much damage could we do continuing to run it if there is a problem in the pump?
jdemaris
08-04-2003 20:16:20
 Re: 3020 Hydraulic in reply to Rick, 08-04-2003 19:02:53
Like the other person answered, check the pump drive and bushings. If you decide it's all tight and the noise is inside the pump, it's most likely to be the stroke-control valve. This is a common wear item in the pump and it can be changed without removing the pump. When it starts to leak or fail, the tractor will usually start harder since the starter motor has to fight the hydraulics. Also, the pump will make a "hammering" sound that will cycle on and off. You can usually silence it temporarily by turning the steering wheel. Other than that, there's a lot more mechanical parts in the pump that can make noise. Two large adjustable Timken bearings, eight intake valves, eight discharge valves, etc. Also, the pump has pistons and springs, eight or four depending on the size of the pump. If any of those springs break it will still function but will be noisy. Because these pistons are a snug fit, if the pump gets any broken parts inside of it, and metal runs through it, it will probably get trashed. Otherwise, these pumps are fairly easy to rebuild.
Bob
08-04-2003 19:59:46
Check the tightness of the spline coupler on the pump, and the flexible drive and/or bushings.
Change the filter.
