JD 4010 12 volt alternator
Jack
08-04-2003 08:50:33
Anyone do a 12 volt conversion on a 4010? What all did you use to hold the alternator on and alighn the belt?
thanks
jack
Bob M
08-05-2003 04:53:51
 Re: JD 4010 12 volt alternator in reply to Jack, 08-04-2003 08:50:33
Jack - I helped put an alternator on a 4020D many years ago. Used a Delco 10SI internally regulated alternator and mounted it by "field modifying" the old generator bracket and tensioning arm. As I remember all it required was welding on a couple pieces of � x 1" bar stock and a bit of 3/8" threaded rod for a pivot.
Another option is to get an alternator bracket off a 4020 from the boneyard. Though it seems to me the 4020 used a Prestolite (or Motorola?) alternator - not sure whether the mounting of a Delco 10SI is the same.
