Ethanol blended fuel, Use it or not?
CK in SD
08-04-2003 05:48:41
What are anyones thoughts on using ethanol blended fuel in their tractors. I was not using it in my 520, but ended up filling it with 10% ethanol blended fuel last time I filled. Now, I can hardly keep it running. Spits & sputters like crazy. I suppose I need a good carb cleaning or kit. Thoughts??
Bus Driver
08-04-2003 15:59:42
 Re: Ethanol blended fuel, Use it or not? in reply to CK in SD, 08-04-2003 05:48:41
Never worked on a 520, but the symptoms sound like a lean mixture- exactly what happens with the addition of ethanol. Takes more volume of ethanol to equal the energy output of gasoline. Asuming that your tractor has adjustable high speed jet(s), adjust the mixture a bit richer. If this helps, it will be necessary to readjust the carburetor if you return to using regular gasoline.
Jake,
08-04-2003 08:57:54
I use it here in Minnesota. Actually most if not all gas has it here in MN except for the pumps marked without ethanol and says only to be used in collector cars, small engine, snowmobiles, outboards, etc.
With the ethanol don't ever have to buy "fuel line deicer", the ethanol blend fuel already does that.
In Minnesots we can also get fuel called "E85" which is 85% ethanol and 15% gasoline that is intended or flexible fuel vehicles. I occasionaly blend a gallon or two of that into a full tank of gasoline on my car or truck to absorb any water that may be in the tank. So far so good.
As one of the other guys said, the stuff may loosen up existing dirt in your fuel system. You'll want to clean it all out anyway.
Some older fuel systems will have hoses and other rubbery parts in the fuel system that can be attacked by the ethanol blend fuels.
Ralph Ia
08-04-2003 07:34:53
I've used Ethanol in all my tractors, pickup, and car a long time with very good results. However, I have a son in law that sells and repairs string trimmers, chain saws, etc. He sure don't like it in them. Eats the rubber hoses that are used.
4020dt
08-04-2003 07:19:55
Mike's right , I have used ethanol blended gas since it came out in late the 70's , use it in all the old tractors as well as carburated and newer fuel injected trucks and cars . NO PROBLEMS !!!! . Use it in SC Case , Farmall H , M , Super A , JD 2020 and lawn mowers . Don't forget ethanol is made from CORN which we have plenty of in the USA and every gallon we use is one less we have to inport and line OPEC's pockets !!!!! !!!!! !!!!
Mike Aylward
08-04-2003 06:08:18
CK, I run ethanol in all my two cylinder tractors. The ethanol's solvent properties will dissolve all the old varnish in the fuel system but once it is cleaned out it will stay clean. I routinely use it in all tractors that I get in. True, you will have to clean your sediment bowl and will have some problems like you are having if the fuel lines and carburetor are full of gunk, but you want that stuff out of there as soon as possible anyway. Once you get all the junk out you will like the way ethanol keeps the fuel system clean. A small headache now to improve the tractor later. "Get it clean, keep it clean". Hope this helps. Mike
daveo
08-04-2003 21:30:48
 Re: Re: Ethanol blended fuel, Use it or not? in reply to Mike Aylward, 08-04-2003 06:08:18
Yes,
I agree the solvent qualities will clean things out. About ten years ago I brought a car out of long term storage that had never had Gasohol in it before. The first thing I do after getting it running is wheel it up to the Gasohol pump and fill it to the brim. Everthing was fine untill the fine mesh filter screen INSIDE of the fuel tank filled with sludge that the alcohol had released from the internals of the fuel tank. After that was resolved everthing has been fine! I use Gasohol in everything except the engines that might be subject to long term storage. The long term storage properties of Gasohol are inferior to straight 'unleaded'.
Burn em' up!
MPK
08-04-2003 21:27:46
I also am from Mn where we have ethanol in almost all our gas. I have used ethanol in my JD 520 and model A since it came out without any problems. I believe the reason I don't have problems is because I have for many years before used a good fuel system cleaner in the gas tank which also cleaned the carburetor, therefor there was no crud left in the system for the ethanol to loosen and cause problems.
