If as original, the top plug terminal fires the left cylinder at its TDC, and then the right cylinder at its TDC 180 degrees later. The Wico X fires both cyliners at BOTH TDC's however, compression and exhaust, so if its installed 180 out and backfires etc., you can make her run by reversing the top and bottom plug wires. WICO TIMING 1) Bring the left hand (flywheel side) cylinder up to TDC on its compression power stroke. You can tell that by removing the plug and rotatign the flywheel CCW to see if shes compressing air (up on compression) out the plug hole or is exhaustign air out the exhaust valve (not compressing air out the plug hole) and use a wire etc in the plug hole to determine when the piston is at TDC. The Wico X fires at both TDC's (power & exhaust) however, so reversing the wires (top to botom) can make them run regardless. 2) At that time, the Left Hand Impulse timign mark on the Flywheel should be in the 3 o clock position in line with a flat mark on the tractors side. Assuming flywheel to crank and it to cam and cam to governor etc are all in time. 3) At that time, just when the left hand impulse mark passes the flat mark at 3 o clock, the mag should snap and fire the left hand plug out the top cap terminal. (or could be reversed if 180 out) 4) To adjust that initial start timing, loosen the mags top n bottom bolts and rotate it CCW to advance and CW to retard to where it snaps to fire as described above. If it fires too soon before that (3 o clock flat mark), the flywheel may kick n spin backwards. 5) THE above sets the initial start timing, while the lag angle adjustment on the mags rear drive coupler sets how far the run time spark advance is set ie how far the start timing lags the run timing, and is normally around 20 to 25 BTDC at running (approx over 250 RPM). Good Luck, God Bless, and post back any more questions. John T Nordhoff in Indiana
