How to identify a Power Block?
CJDave
10-20-2003 17:43:16
A guy who was helping me with some shop furnace issues looked at our JD "A" today and said: "Oh, I see it has a 'Power Block'". That was news to me, but I really have NO IDEA how to tell if it has one or not. He was going by the yellow paint that is showing through the green "shotgun" paint job that the tractor has now. A leaky top water pipe allowed coolant to sort of leach the green paint off and some yellow is showing on the block. Is there a way to tell if it is a Power Block?
CJDave
10-20-2003 20:28:11
 Re: How to identify a Power Block? in reply to CJDave, 10-20-2003 17:43:16
Thanks for the clues. I'll take a close look and see if it has any stampings. This tractor was neve pulled so it may still have the original stamps. This tractor is a 1952 A.
730-LP
10-20-2003 20:07:23
CJDave some times if the tractor has been used in tractor pulls the writing will be ground off but to tell if it is a power block look on the bottom of the block a power block WILL NOT have cockpits are a place to put them.
Bill R
10-20-2003 19:12:21
It sould be stamped on top of the block on the mag/distributor something POWERBLOCK or 6 inch or something of that nature, don't remember what it is exactly.
Hank
10-20-2003 19:38:47
 Re: Re: How to identify a Power Block? in reply to Bill R, 10-20-2003 19:12:21
On top of the block it will be stamped no. 1 or 2 power block 6 inch. The numbers 2 is for a early styled JD.
Denny Foster
10-21-2003 05:18:51
 Re: Re: Re: How to identify a Power Block? in reply to Hank, 10-20-2003 19:38:47
Ok guys, clue me in on this one?? What is a power block? is it bored or is it something special that Deere made??
Denny
Robert
10-21-2003 05:45:34
 Re: Re: Re: Re: How to identify a Power Block? in reply to Denny Foster, 10-21-2003 05:18:51
I have a 6-1 Power Block on my 1945 A. As others have posted, it has a 6" bore. My understanding is that they were an aftermarket item sold by the old Tractor Supply Company, and allowed the user to increase the horsepower of the engine by just exchanging the block and pistons, utilizing the original rods, wrist pins, and head. I believe the conversion also included higher compression aluminum pistons.
Mine also happens to have the later gas manifold as opposed to the all-fuel, and a DLTX 71 carburetor.
The words "Power Block" and "6 1" are cast into the block.
I think there were other versions, such as 6 2, and 6 3 for the later model years, but can't tell you how they differ from the 6 1.
Denny Foster
10-21-2003 05:56:03
 Re: Re: Re: Re: Re: How to identify a Power Block? in reply to Robert, 10-21-2003 05:45:34
Thanks for the info, I had seen the term "powerblock" mentioned before but I did not have a clue what it meant.
Denny
