JD 2130 hydraulic shudder -- accumulator?
scott
08-03-2003 20:30:22
folks -- I have a 2130 that has a shudder in the rear hydraulics, lift arm or loader, it is constant, not like air or intermittant, you can count the pulses, like d-d-d-d-d-d-d-d, while going up, steering is normal, everything else seems normal, it has FWDA and an accumulator on the side of the engine, could that be it? Also, have a valve/sensor on the hydraulic line going to the rear lift valve that has three wires on it, I believe its for the 4x4 control? Any help would be appreciated!
BTW, just fixed the brakes and got all the metal out of the system, found all the info on this board, thanks guys!
scott
[email protected]
scott
08-03-2003 20:41:45
 Re: JD 2130 hydraulic shudder -- accumulator? in reply to scott, 08-03-2003 20:30:22
also -- have changed all filters and oil!
