70 first reduction gear oil
Dave
08-03-2003 20:17:04
I changed the trans oil in my 70 gas this weekend. The manual says the first reduction gear takes 1.5 quarts. I screwed up and dumped in a shade over two quarts. Should I drain some out, or will a little excess not cause a problem? Thanks.
Clooney
08-04-2003 03:20:25
 Re: 70 first reduction gear oil in reply to Dave, 08-03-2003 20:17:04
Dave, don't worry about it. The 1st reduction cover area is somewhat open to the trans sump so the 1st reduction area will seek the same level as the trans oil. The reason Deere has you add gear oil to the 1st reduction area is so you don't operate the tractor before the sump fills on it's own as the oil moves very slowly between the trans & 1st reduction area.
will
08-04-2003 18:07:15
 Re: Re: 70 first reduction gear oil in reply to Clooney , 08-04-2003 03:20:25
How slowly does it move? I changed mine, and didnt put oil in my gear cover, but mine sat for a few days before I used it. What do you think? Should I go ahead and add it anyways? Thanks so much. I will read the manual next time.
Dave
08-04-2003 07:23:12
Thanks, Clooney, and all the others who replied. That's one less thing for me to worry about.
Bill
08-03-2003 20:31:33
some is good ...more is better ,,,,Dont worry about it;;;;;; it will drain to the right place,,,,, ,Bill
Tim
08-03-2003 20:30:22
Dave That extra 2 quarts wont hurt
