520 LP Carb. rebuild.......
Tyler-MO
08-03-2003 12:31:05
I am in the restoration process on my 520 LP. I would like to rebuild the carberator (or really it's a fuel mixing valve) but regardless I need to get it right. I'm wondering if anyone out there has rebuilt their LP carbs or know of anyone that will rebuild mine and is good at it. Thanks for any ideas
Tyler
Van
08-04-2003 09:26:35
 Re: 520 LP Carb. rebuild....... in reply to Tyler-MO, 08-03-2003 12:31:05
I have a 4010 LP out of eastern Ark and also one of those "red" LP tractors the carbs are way more easier to work on than the gas versions once you get into them, best advise---get the manual
Loren Viterna
08-04-2003 08:48:59
Tyler, Rebuilding the LP carb is a snap compared to the gas carb. The manual is available from Deere. Just follow it. I recently rebuilt my 530LP carb and the only part I found to be difficult was getting the throttle valves to seat evenly on the nozzles. Between the parts book and the carb manual you should have no problems. E-mail if I can help you in any way.
Duane Larson
08-03-2003 13:01:28
Tyler-MO
SM 2024, the JD Service Manual for carburetors, has a section on rebuilding these carbs, if you want to do it yourself.
I believe the manual itself is still available from JD - 1-800-522-7448.
andrew
08-03-2003 20:14:10
 Re: Re: 520 LP Carb. rebuild....... in reply to Duane Larson, 08-03-2003 13:01:28
eastern arkansas is full of lp deeres. and most of the folks say the parts for the converters are becoming hard to come by , which in turn should make those tractors worth more. I've heard that they are not to diffucult to work on if you get the manual.
