Wayne in Tn.
08-03-2003 10:49:00
Re: Hyd on a 40 in reply to JR in TX, 08-03-2003 10:15:45
JR, First, the manual calls for 10w non-detergent motor oil for the Dual Touch-o- Matic system. The lever underneath the seat on the left is for dual or independant operation of the dual control levers. Damage can occur to the unit if not operated in the correct position...The correct position for Dual use is move this lever FORWARD, make sure the two pins come out (may have to pull them out with pliers) Then make sure the big pin is pinning the two left lift arms together. Then move the INSIDE control knob to the UP position and lock it there with the wing nut,,therefore dis-ableing it for use. THEN, only use the OUTSIDE knob for use with regular 3-point equipment. This makes both pistons work in unision to lift the equipment. As to repair of the unit itself, to eliminate slow or weak operation, you will have to remove it and do a tear-down and replace the seals, o-ring, gaskets and piston & head rings, also cleaning everything spotless, there is no filter on this system. If you plan on repairing it your self, I would reccomend the Parts Catalog # PC862 and the Service Manual # SM2013 Unless you are familiar with this system, it is almost impossible to rebuild them without the manuals. Cost for all the repair parts is approx. $150 I have rebuilt a bunch of these in the past few years, with 100% success, except for stopping the leaks at the lift arms.
