Hey Mike Hanley
Rooster in Tenn
08-03-2003 07:06:19
Thank you for the reply. I think that is were the oil is comming from. A another question is how do you get the lines lose? Some time back I had to pull the pump, to work on the governor. But I couldn't get the lines alose. Also what is behind the box?
MIKE HANLEY
08-03-2003 08:14:46
 Re: Hey Mike Hanley in reply to Rooster in Tenn, 08-03-2003 07:06:19
There really isn't much behind the box. The oil comes into the box and all the valves are in the box. What you will see when the box is off is a machined surface with two holes. That is where the "O" rings go. The harest part of the job will be to clean off the old gasket. The Box is heavy. As to removing the lines,,,alot of luck. You may have to give them a good soak of WD-40 or something like that. I use a tire iron at the first bend back from the ends and use a jerking pull and some light taps at the ends. Don't hit it to hard as the lines are thin tubes and dent easyly. I have had good luck at the pumps by just putting in new "o" rings when putting back the lines. But have had some leaks were the lines go back into the box with some minor leaks after a while. So I just now put in two "O" rings into the box and then push back in the lines. A little never-sease on the ends around the tubes away from the "O" ring lip will help for next time.
