A push rod tubes
randy
08-02-2003 19:20:12
Does an unstyled A have push rod tubes in the head that could leak water in the oil
David Bacon
08-02-2003 21:24:32
 Re: A push rod tubes in reply to randy, 08-02-2003 19:20:12
The No. 1 rule of thumb with with water going through a 2 cylinder is check the push rod tubes. The second rule is if it still leaks check them again. Very common problem Dave in NE Iowa
Will P
08-02-2003 20:20:46
Like Frank has said, yep.
Will P
F-I-T
08-02-2003 19:37:42
The parts catalog shows push rod tubes (2 of them) used in heads up through S/N 487,999.
Frank-in-Tallahassee
70D // 855
