FLYWHEEL PLAY
LUKE
01-16-2004 14:20:19
I TOOK THE FLYWHELL COVER OFF MY 720D TO CHECK THE STARTING MOTOR CLUTCH. FOUND THAT SOME TIME IN ITS LIFE SOMEONE WELDED THE FLYWHEEL TO THE SHAFT. ALSO HAVE MORE PLAY THAN I THINK IT SHOULD HAVE. ONLY USE THE TRACTOR FOR PARADES AND TRACTOR RIDES NEVER HAS TO WORK. WILL THIS CAUSE ME A PROBLEM?
Clooney
01-16-2004 17:52:11
 Re: FLYWHEEL PLAY in reply to LUKE, 01-16-2004 14:20:19
LUKE, probably not.. As long as the weld is good & solid & has held good for years it will probably hold longer for light usage..
~On the crank end play, you are pretty well stuck with what you have. If you try to mess with it now you might end up putting a crankshaft & flywheel on it.. If the end play gets too extreme the inner thrust washer could fall out of place & break & that is not a good thing..
~You are probably looking at a costly repair with a lot of work involved so just let it run.. It might hold up for a long time into the future.. When it fails you will have to address the problem...
[email protected]
Will-Mn.
01-16-2004 14:30:06
Let sleeping dogs lay,also the Irish have a saying "if it works don't fix it"
My uncle had a John Deer 730 diesel electric start,after awhile the flywheel came loose,as in worn splines,so they welded it,not long after that it broke right off! (the crankshaft) so he replaced the crankshaft with it's matching flywheel,after that no more problems,and that was years ago... i heard a rummor that cranks were made with the matching flywheels i do not have facts to back this up,perhaps others here are more informed than i am on the matter of matching cranks n flywheels.
Will
tractorboy
01-16-2004 15:14:15
 Re: Re: FLYWHEEL PLAY in reply to Will-Mn., 01-16-2004 14:30:06
Yes they were matched unit when they left the factory and were balanced together. You should try to buy replacements as a matched pair. They are usually marked on the end of the crank and near the center of flywheel. I have mismatched these before on different tractors with good luck, but there is a slight chance that the balance of the two could be a little off but it probably would not cause any problems. TSC has been exchanging flywheels for years.
