1944 B Water in Push Rod Passages of Cylinder Bloc
David Lile
08-02-2003 18:37:19
This 44 B has not been started in 10 years, in the process of restoration I pulled the head. Had it milled and valve job. I did not have any work done to the Cylinder Block it all looked fine. Problem water seeping in very slowly into the Push Rod Passages of Cylinder Block. I cannot pinpoint the exact spot of where the water is coming from all I know is after installing the head even with new gasket and gasket sealer I have water accumulating inside the Push Rod Passages of the Cylinder Block. I suspect cracked block around the passages or bad rear cylinder block gasket.
Any Ideas?
Paul from MI
08-03-2003 19:29:47
 Re: 1944 B Water in Push Rod Passages of Cylinder in reply to David Lile, 08-02-2003 18:37:19
It is possible to have cracked pushrod passages in the block. I had one on my 44 B due to freezing. It took a while to find it. The only fix I know of is to replace the block.
Paul
Will P
08-02-2003 19:16:00
The head has push rod tubes. You will have to replace the tubes. It is easyest to take the head off to do this. Who ever did your head should have replaced them.
Will P
David Lile
08-02-2003 20:24:55
 Re: Re: 1944 B Water in Push Rod Passages of Cylin in reply to Will P, 08-02-2003 19:16:00
The push rod tubes in head look fine. I can look clear thru head and cylinder block with a flashlight. The water is pooling up in the cylinder block not the head.
Will P
08-02-2003 21:01:31
 Re: Re: Re: 1944 B Water in Push Rod Passages of C in reply to David Lile, 08-02-2003 20:24:55
Passage in block is bigger than the tubes in the head. Probably is leaking out the back side of the tubes and pooling in the block. Is it pooling only in the two center push-rod passages or all 4?
Will P
David Lile
08-03-2003 13:11:41
 Re: Re: Re: Re: 1944 B Water in Push Rod Passages in reply to Will P, 08-02-2003 21:01:31
Water is pooling in all four. Of course about half way back in cylinder block there is a passage that connects the passages, so if one had water in it. It would fill up two push rod passages.
In the book "How to Restore Your John Deere Two-Cylinder Tractor" it says the gasket between the maincase and the cylinder block is a common source of leaks.
I just pulled the head for the third time. Water was pooled in all four passages. Still no sign of where the water is coming in at.
F-I-T
08-03-2003 13:40:05
 Re: Re: Re: Re: Re: 1944 B Water in Push Rod Passa in reply to David Lile, 08-03-2003 13:11:41
third party image
David:
Unless I'm not understanding your question, there is no way the block to main gasket can cause a water leak, no matter how that book reads. The water passages don't go all the way through the block, meaning you can stand the block up on its end and fill it with water and it will not leak out. Refer to the picture.
If you are getting water into the pushrod area, you have either a leaking pushrod tube, a cracked head or block, or a bad head gasket seal.
Frank-in-Tallahassee
70D // 855
David Lile
08-03-2003 15:10:19
 Re: Re: Re: Re: Re: Re: 1944 B Water in Push Rod P in reply to F-I-T, 08-03-2003 13:40:05
Thanks for the insight, I guess the book was talking about oil leaks on the gasket between the maincase and cylinder block not water leaks.
Your right the leaking water is in one of the areas you described.
1. Pushrod tube in head. Looks good.
2. Cracked head. No signs of cracks, I had it machined it looked good.
3. Cracked cylinder block. I pulled the head, chained the front end of tractor to 14'tall rafter in ceiling and hoisted front end of tractor straight up. Then filled block with water I still couldn't find any leak in block.
4. Bad head gasket seal. I have put a new head gasket on 3 seperate times with sealer.
Water still pools up in the Push Rod Passage of block. I don't know what to do next.
F-I-T
08-03-2003 15:51:48
 Re: Re: Re: Re: Re: Re: Re: 1944 B Water in Push R in reply to David Lile, 08-03-2003 15:10:19
David:
I have already fabricated a masonite template to fit the block side of the head, sealed with it with Permetex and through bolted it in place. All you have to ensure is that there is a hole for each pushrod opening. Put in the drain plug, and fill with water. Best if you could pressure test it, but I'll bet that would reveal a leak in an otherwise good looking pushrod tube. It's got to be in one of those places.
Frank
David Lile
08-03-2003 17:22:58
 Re: Re: Re: Re: Re: Re: Re: Re: 1944 B Water in Pu in reply to F-I-T, 08-03-2003 15:51:48
Thanks for all the help.
