3010 Top Link
Andy Carstensen
01-16-2004 14:02:05
Why is it that the top links I have seen have a different size hole on the tractor end than on my 3010? The mounting holes on my 3010 are smaller than the mounting holes for a 4020/3020. Was there a different end that was manufactured for a while or will I have to sleeve or bush the end to work or redrill the holes on my 3010.
Dick in MI
01-17-2004 09:29:17
 Re: 3010 Top Link in reply to Andy Carstensen, 01-16-2004 14:02:05
Andy The top link on my 3010 has a cast universal joint on it.It'sall part of the screw shaft,and uses a 3/4 T pin with a clip for the end.Wish I knew how to post a pic it would be easer to see Dick
67 2020
01-16-2004 17:20:22
Good question. My 67 and 71 2020 top links don't match common pin sizes either. They look to be about 1/16" smaller in diameter. When using any other direct connect implement I have to bush'em. David
