Hydraulic Oil
Rooster in Tenn
08-02-2003 17:44:59
I have a 720, the Powr-Trol was working good, But I had a small leak at the bottom of the Remote Cylinder Housing. The leak is between the Housing & the powershaft. So today I go to the barn and all the the oil is on the floor. Just use it a week ago, Leaked a little but was never over half empty. But today it is dry as bone. Any help would helpful, because I don't have clue.
MIKE HANLEY
08-02-2003 20:28:17
 Re: Hydraulic Oil in reply to Rooster in Tenn, 08-02-2003 17:44:59
Do you mean it's leaking out of the box and onto the powershaft? Do you have a rockshaft with the load and depth control? (the parts where the upper link of the three point pin in. I have yet to see one that didn't leak here.) Claen it all up dry and put in more oil and watch where it comes from. Oil will run half way across a tractor before it deciedes to finally hit the ground. If it looks like it's leaking from behind the box (where the levers attachach to,) thats an easy fix. The box has a gasket, but there ars "O" rings back there also. The differance between single remote and duel remote is all in the box and to change means to just change the box. The gasket is differant but it takes the same "O" rings. Even if you never done that before, 1 hour tops to pull the box and put it back on. Have the new gasket and "O" rings ready to go. Another place it likes to leak with age is the "O" rings in the return line back to the pump.
Iulian
08-11-2003 03:24:12
 Re: Re: Hydraulic Oil in reply to MIKE HANLEY, 08-02-2003 20:28:17
I am from Romania and i would like do have a book about john deere's hydraulic system.If you can,send it on my e-mail.
Thanks!
Iulian
08-11-2003 03:26:54
 Re: Re: Re: Hydraulic Oil in reply to Iulian, 08-11-2003 03:24:12
Thanks!
I have a John Deere 4240S
