Hi Ken, I just got back from a weekend outing so just now gettign caught up. First, do you have a 6 or a 12 volt battery in the tractor??? cuz you need to buy a matching voltage cut out relay. Its job is to close when the gens voltage is higher than the battery so it can charge it, but open otherwise like if the tractor is off so the battery dont reverse discharge through the generator. Next, your tractor was originally positive ground, so the cut out relay has to either be a positive ground model or a bi polar type which is reversible and works on either (+ or - ground) which its labeling or instructions show how to wire for either. The bi polar reversible models just get reverse wired one way or the other to suit + or - ground systems. Third, it will wire with one terminal "maybe" marked BAT (on original for + grnd JD) to the load (non battery) side of the ammeter and the other terminal "maybe" marked ARM or GEN to the armature (larger of the 2) posts on the generator and its mounting to a good ground. Or it may be marked like + and - and have instructions how to wire for what ground system you have. The wire to charge the battery (the non to gen wire) has to be connected to the battery so it can charge it, with the usual path to and through the ammeter, then the starter post, so be sure thers hot battery voltage on the relays BAT side at all times when you find the wire that atatches to it (should lead to load (non battery) side of ammeter if it has an ammeter, or to batetry or starter post otherwise. On most cut out relay type systems, the generators current output is controlled by how good a ground you attach to the generators field (smaller of the 2) posts with a dead ground for high charge when lights are on but via a resistor to ground for low charge when lights are off. Thats done by using a dual purpose light and field ground type switch. Also, many of those generators are three brush types with adjustable current output dependign on how close you adjust the third brush to the one on its same side. NOW as far as dead groundign the field as you asked via a switch to ground, its true that will cause max charge, but overcharging a battery is bad, can ruin it, plus over flow acid out the top. If you wanted to go to the trouble of watchign an ammeter and/or had a voltmeter also installed, you may be able to dead ground teh field for periods then open it by manually switching and keep the battery charged but not overchargre it, but thats your choice and decision even though I cant recommend it. The best method is to install a true full fledged 3 wire Voltage Regulator, either an original type for a + ground JD system or one (generic type) for a + ground if youre at positive ground, or a bi polar type that works on either. Then install and polarize it and your good to go. Be sure the belt is good and tight, the gen and relay or VR well grounded, wiring is right. Good Luck, God Bless, and post back any more questions. John T Nordhoff in Indiana
