58 420 5 speed with continuous pto sn 130100When I got this beast running it had a rattle/chatter/ratcheting noise in 5th gear when not under load or deceleration. I eventually broke enough gears off the ring gear that I had to replace the ring and pinion. All trans shaft pre load and end play was set at the time and bearings replaced if needed. The gears on the output shaft look right and have the correct number of teeth. The gears on the input shaft look right and have the correct number of teeth. I did not disassemble the gears on the imput shaft. I have discovered that the 1st 5th sliding gear does not go but about 1/3 of the way on the gear on the input shaft. I have compared the measurements of the forks and shift detents to a known good one and they appear to be right on. I am thinking that the drive gear set for 5th that is on the imput shaft may be from a different trans and thus account for the misalignment even though the teeth are the correct number. If anyone knows the answer by going to the school of hard knocks or other wise, I sure would appreciate the feed back. Thanks for wading thru the long post.
