Hey Dan, Im not the clooney (just got on line this fine morning) but maybe can throw my additional 2 cents worth in to try n help get the old girl up n running. On those 4 wire Voltage Regulators that have terminals (BAT, ARM, FIELD and LOAD), the ARM (or GEN) post is often over on a side all by itself or even down under the bottom, and its supposed to be wired to the Armature (larger of the 2) generator posts. As posted below, the other VR terminals wired FLD to Gens Field (smaller of 2) posts, LOAD to light switch, BAT to load (non battery) side of ammeter. To make a generator run like a motor, you would apply battery voltage to its Armature post (or the ARM terminal on the VR assuming its wired in right), so maybe you indeed have battery voltage present on it????? ??? The cut out relay portion inside the VR is supposed to close to connect the BAT and ARM terminals on the VR when the gens voltage exceeds the batterys to charge it, but open otherwise when tractor is off so the battery dont discharge. If thats stuck (relay contacts carbon and stick closed) then the generator would draw current and try and run like a motor, so you may a have a wrong wirign connection or a stuck closed cut out relay inside the VR maybe????? ? Hope this adds some insight and you get the D up n running, even though I not much into the D's actually. Good Luck n God Bless Ya "Dan the D Man" John T Nordhoff
