420/430 water pump repair
Henry J
08-01-2003 15:59:56
The bearing in my water pump is toast. I disassembled the pump thinking i might be able to get a repair kit. When I looked in the parts book it shows the shaft coming with bearing installed and no repair kit. I shudder thinking what the price of the shaft and bearing alone will be.
Anyone out there know where a kit is availabel or maybe where the bearing can be purchased by itself. Thanks
Dale in IN
08-02-2003 07:10:19
 Re: 420/430 water pump repair in reply to Henry J, 08-01-2003 15:59:56
Just had the water pump on a 6600 combine rebuilt by deere dealer about a week a go. That bearing is standard on most of their water pumps. generally a stock item.Also had to replace my impeller. The one that was in the machine was plastic and it stripped all the spokes out of it. The new one was cast and looked like it should last forever. Total cost including labor and gaskets was $75.53. There has to be some press work done to rebuild these pumps. Let the dealer do it then if they break it they are responsible.
Wayne in Tn.
08-01-2003 17:06:55
Henry J. That comes as a complete unit (bearing and shaft). Part # JD8549T The Deere web parts page shows it not available anymore, but you may can still get it through your local Deere dealer. I recently installed one of those, but the guy I bought the tractor from gave the part to me with the tractor. So I can't tell you the cost. You will also need the seal (AF2057R) the gaskets (M3047T and M3046T) and (M3219T) Also don"t forget to put the small washer (key # 4) back when installing the pump or you will break the housing when tightening the bolts.
Henry J
08-01-2003 17:53:51
 Re: Re: 420/430 water pump repair in reply to Wayne in Tn., 08-01-2003 17:06:55
Thanks Wayne
I can make your day(FIT)
08-01-2003 19:14:16
 Re: Re: Re: 420/430 water pump repair in reply to Henry J, 08-01-2003 17:53:51
Henry J:
I THINK if you go to the JDParts page, and type in JD8549, and leave off the "T", you get a description that says "Ball Bearing". The accompanying diagram sure looks like a water pump shaft and bearing unit.
The price shown is $ 22.08, and that is generally less at the dealer. I know the similar part for my '70'D was under $20.00.
Frank-in-Tallahassee
70D // 855
Wayne inTn.
08-02-2003 08:21:09
 Re: Re: Re: Re: 420/430 water pump repair in reply to I can make your day(FIT), 08-01-2003 19:14:16
Frank and Henry J. I tried it again and left off the (t) It shows that the new number is JD9377 now and gives a price of a little over $17 It does look like the right part, maybe check the measurements in the diagram against the removed part.
Henry J
08-02-2003 05:27:32
Thanks Frank
I should a done my homework, that sounds affordable.
