4020 anti-freeze leak
JW
08-01-2003 15:16:31
Looked at a 4020 dsl that was for sale, nice tractor that was overhauled by Deere dealer 80 hours ago(documented) but it is weeping at one of the weep holes. Tractor had not been used all spring and the oil looks fine. The leak seemed to stop after it warmed up(was just a small wet streak on the block when it did leak. Is it anything to worry about or not. Guy that has it is in his mid 80's so he doesn't use it much if that makes any difference.
Bob
08-01-2003 22:13:44
 Re: 4020 anti-freeze leak in reply to JW, 08-01-2003 15:16:31
There are three grooves on the block. Top one is for "O" ring that seals sleeve to water jacket. Middle groove is open to weep hole that allows coolant or crankcase oil to leak to the outside if either of the "O" rings is not doing it's job. Bottom groove is for "O" ring that seals sleave to crankcase. If you have water coming out the weep hole only 80 hours after a rebuild, (assuming the that sleeves were replaced), the upper "O" ring probably got torn when the sleeve was installed, or the block is severely rust pitted in the "O" ring groove, or the guy that put in the sleeves did not adequately clean the "O" ring groove.
If you plan to keep the tractor for the long term, leakage here is not a good idea.
To fix it (assuming the sleeve is only 80 hours old and the block is not pitted or cracked severely) would cost a valve cover gasket, head gasket, a couple of "O" rings, a pan gasket, a bearing insert and rod bolts, and quite a bit of labor.
4020dt
08-02-2003 06:18:28
 Re: Re: 4020 anti-freeze leak in reply to Bob, 08-01-2003 22:13:44
I will add one other thing , use only OEM JD o-rings , I had trouble over the years with o rings that came with after market sleeves and pistons . They weren't the right size , material or something , the sleeve slipped in too easily . One I did with M&W many years ago leaked before it ever ran . I had to tear it down and used Deere o rings they fit a lot tighter and didn't leak . The grooves were clean and good , had only 1500hrs on it . From then on I used oem rings .
John
08-01-2003 18:40:27
Check the archives on this subject. There was a post on the same weepholes about 4-5 months ago. If I remember the post correctly the weepholes kept oil and coolant from each other if they ever bypassed their respective seals and unless the fluids are pouring from them theres nothing to worry about.
John51
08-01-2003 18:39:44
Leaking around the sleeve-the seals go bad but only 80 hours on a rebuild?
Anyway, I've had one that way for 5 years now. Was going to tear it down but didn't get to it so I kept on running it with no apparent problems. No water in the oil, so I'll go until it gets worse.
JimKS
08-01-2003 18:02:55
What weep hole is it leaking from? the one on the water pump? If that's the case, the water pump needs rebuilt... no big deal really.
JW
08-01-2003 18:15:56
 Re: Re: 4020 anti-freeze leak in reply to JimKS, 08-01-2003 18:02:55
No, one on the block by the starter
