#30 thrower question
Brandon
07-31-2003 20:17:17
I have rigged my 327 up with a bale chute inside the thrower to load bales onto flat wagons. Should I take the belts off the flywheel that run the pump when I'm not using the thrower?? I'd rather use the thrower but right now i have more flat wagons than thrower racks. Thanks for the replys. Brandon
TB SCOTT
08-01-2003 08:49:02
 Re: #30 thrower question in reply to Brandon, 07-31-2003 20:17:17
I'm probably in the same boat as you are. I just put a #30 on a 336 and love the way it loads into my 1 wagon. I put my chute back on to load onto my 3 flatbed wagons and removed the belts. It only takes a minute to loosen the tension bolt. I had nightmares thinking about what would happen in I had my chute in it and the lockout failed and the thrower tried to activate some how. Self destruction !!!!! ! good luck ..:-)
