45B DTX 13 Carb Bottom nut won't come OFF
Ben.SoTex
07-31-2003 19:04:32
I have my father 45 B, I just got it home yesterday, and I took the carb off the tractor, but I can't get the bottom nut off, I put some heat to it and even try a impact wrench and it won't move. I don't want to break the stem off. I need some thoughts/ideas on how to remove it.. Thanks Ben
Duane Larson
07-31-2003 19:59:18
 Re: 45B DTX 13 Carb Bottom nut won't come OFF in reply to Ben.SoTex, 07-31-2003 19:04:32
Ben.SoTex,
Tricky problem! I am a believer in heat from an oxy-acetylene torch, but before you do too much of that you want to ensure all the gasoline is out of the bowl. I normally remove the bowl drain and put the carb in some very hot soapy water, even boiling, and let it cook for awhile. Let it dry, put a 1/8 pipe thread plug back in the drain plug hole and apply heat to the hex sides of the bowl nut. You will be able to burn the gasket between the bowl nut and bowl off, and that will give some room for the next trick. When the bowl nut is red hot, place some shavings from a candle between the nut and bowl. The shavings will melt and if carefully placed, the wax will run around the threads and provide some lubrication. No limit on the number of shavings! Any spray-on lubricant will immediately evaporate, if not flame out. Then let everything cool, and try removing the nut again. Patience is a real virtue here, and it is a lot cheaper than breaking the neck! If it doesn't come off, try the process over again - so far it has always worked for me. The main problem is if heat is applied for too long it may melt the solder on the float and you will need a new float, still a lot cheaper than fixing a neck.
