DLTX 53 carb leaking on my A?
Mike (NE)
07-31-2003 16:30:22
I am trying to fix this carb on my A from leaking. I had the bowl part off today and it has stopped leaking but now it is leaking from the seal that goes from the carb to the exhaust manifold and is dripping down under the carb where there is a threaded hole. Is it overflowing inside still u think? Maybe I need a carb kit, where can these be found? Some idiot painted the darn thing with the tractor! So hopefully there is paint inside. Any thoughts would be appreciated. Thanks
Clooney
08-01-2003 03:47:28
 Re: DLTX 53 carb leaking on my A? in reply to Mike (NE), 07-31-2003 16:30:22
Mike, as Duane said you could have a leaking needle & seat. Just take it out, CLEAN IT REAL GOOD, then insert the needle in the seat & [here is the bad part] place the threaded end of the seat between your lips & suck a little vacuum on the seat, then while still sucking, place the tip of your tong over the little hole in the end of the seat where the needle seats. IF, the needle & seat are holding the seat will stick to your tong tip for a while. If it falls right off the needle or seat is leaking�.Don�t look at me like that! It�s in the manual & actually works good for a quick needle/seat integrity test..
~The other possibility is you have a plugged carb bowl vent or bowl vent baffles [IF your carb has them]. If the bowl vent is plugged it will allow fuel to siphon out of the main nozzle after the tractor is shut off. The bowl vent is in the top of the main carb casting inside the float bowl [on the top] & runs to the choke plate area�.
Mike (NE)
08-01-2003 12:21:11
 Re: Re: DLTX 53 carb leaking on my A? in reply to Clooney , 08-01-2003 03:47:28
This sounds very interesting! Thanks for the tips and hopefully I can get it fixed soon. It is the last step I believe before the old girl gets her new paint. I guess I will find out if I am good with my tongue. lol
Duane Larson
07-31-2003 20:12:24
Mike(NE),
In my experience, it is not uncommon for a new needle and seat to leak. I pull a vacuum on a new needle and seat prior to installing. If a vacuum can't be held, I work on the needle and seat until it does hold vacuum - it will then shut off properly in a gasoline environment. Quality control is not what is should be - looking carefully with magnifying equipment shows roughness both on needles and seats. With this procedure, at least the carb is not leaking when it leaves the shop! The easiest thing to try is to place the needle in the seat (assuming neither are viton) and give the needle a light rap with a hammer. If this doesn't do it, I use aluminum oxide polishing compound, spinning the seat in the lathe and holding the needle in place.
You might try Robert's Carburetor Repair, www.robertscarbrepair.com for repairs for your carb.
dwm
07-31-2003 17:18:16
Yes, it sounds like gas is going by the needle valve and seat, meaning the float isn't able to shut off the flow like it should. We had a similar problem on a DLTX 71 for an A, even after we put the kit in. First time around, we replaced the needle and seat and it still leaked through and put some gas in the crankcase. You need to check for this as gas will go down the manifold, past the pistons/rings, and into the crankcase. Second time, checked the float more closely, seemed to be fine, put another new needle and seat in, this time from John Deere. After a few days, still leaked through. Finally fixed it by replacing the float, which we also got from JD. The original float seemed dry, but the new one fixed the problem. No longer have to turn the gas on and off at the sediment bowl. Also, there are plenty of posts in the archive on this subject, as well as properly setting up the carb. Good luck.
