4020--no brake on PTO
JaD
07-31-2003 05:20:27
Recently purchased a 4020 with power shift. The brake does not work on PTO -always turning have to shut engine off to connect shaft. Is this big problems? Any suggestions or ideas to help??
mike J
07-31-2003 19:38:31
 Re: 4020--no brake on PTO in reply to JaD, 07-31-2003 05:20:27
on the early 3020-4020 they had to of small pin on the brake itself they would break off there was a service bulletin out on them years ago we have a 3020 that had the problem they drill it out and put in a bigger pin and the tractor does have to be split unless you are lucky and it is just linkage
4020
07-31-2003 10:20:43
Or you have a cotter key broke and in order to fix this you have to split the tractor. Mine has been spinning for over twenty years. Stops spinning when a light load is on the pto shaft.
davidval
07-31-2003 07:42:07
connect a gauge to the pto brake and the pto clutch ports at the valve block under the inching pedal, one at a time.
clutch pressure should equal system pressure when pto clutch is engaged (about 170 psi), and zero when the brake is engaged. brake pressure should equal system pressure when pto brake is engaged and zero when clutch is engaged.
if pressures are ok then the problem can be with a dragging pto clutch or bad pto brake. try stopping the pto with a pice of wood. if it stops then the brake is bad (need to split the tractor in three). if it doesn't stop, then the clutch is dragging (split in two) with possible damage to the brake.
if pressures are NOT ok, first thing to do is to remove the panel under the steering and look for play between the lever and the shaft going into the valve. if there is a play, then replace the lever.(used to wear on the older tractors). if there is no play then adjust the linkage.
david
Rodney A Johnson
07-31-2003 06:06:50
Sounds like the valve for the PTO is worn or the linkage is not set correctly. A JD service manual will explain how to set the linkage from the PTO lever to the hydraulic valve.
If someone recently had that area of the tractor apart (like the previous owner), it could be possible that they did not get the linkage properly adjusted.
If the linkage is properly adjusted, then the hydraulic valve needs some work...probably new o-rings. Again the service manual would describe how to do this. From what I remember reading about it, I don't think it was too difficult to do even for a novice...if you have the service manual.
